supaidaaman
- Jan 12, 2006
This is the continuation of an older thread where i never figured out the problem, but i thought i had fixed it.
http://forums.anandtech.com/messageview.aspx?catid=27&threadid=1984149
Problem:
The computer will randomly slow to a crawl, apps wont load, i am unable to end processes or shutdown.
For a few weeks now i had not installed a raid onto my computer, i was currently using a WD 150 raptor. I had no problems, it was my 6th fresh windows install with minimum parts and drivers. I figured the problem had gone, so i installed all my programs and games...then i thought "hey ill try out my raid again, because its going to be time to video edit soon."
When the problem has happened:
-Firefox
-CD installation crash
-Real Player and Firefox
-Sandra test
-After effects loading
-one time i checked "my computer" and it happened
-random times
Its the 3rd day since my raid install and i got my first slowdown sluggish OS crawl of death. I was listening to some music with firefox open, and BAM! it happens. Quickly i ran speedfan, and sandra to test my voltages and look at temp settings. Everything was fine. For the next 10min my computer was slow and unresponsive but amazingly i was able to run benchmarks in Sandra flawlessly. (very weird) Programs that i closed where gone, but their processes remained, and were unstoppable.
After about 10min the problem seemed to vanish, but i was unable to shutdown, so i reset.
What i know is not the problem:
Not sata power
Not sata cables
Not Overclocking
Not memory errors(ran memtest lastnight for 10 hours and 10 tests of test 5)
What i think it might be.
-When i install the NVraid, the problem happens, and when i remove the raid it is still there
-PSU might be bad? but ive changed up the molex/sata cables and the voltages are normal
-I ran my system with SW IDE driver installed with no raid for 3 weeks no problem, but in order to see the raid i had to install the IDE driver again for some reason, (so maybe going over the old driver messed up)
-Could one of the raid drives be bad? Ive run SMART on all the drives already and formatted them all many times, all are perfect according to test software.
Im losing my mind, i just installed over 30gigs of apps and video editing software as well as old video data for editing...plus i just started my new school term. Is there anyway i can image 50gigs off this OS install ( i have it perfect now) so when i do a reformat, i can be set up and ready to go right off?
Problem:
-Firefox
-Sandra test
-random times
Not sata power
Not sata cables
Not Overclocking
