Like the title says I'm having a problem with my new SSD and I cannot figure it out.
I recently grabbed a Crucial 256gb m4 SSD due to one of the threads here, it got here today and it's having some issues so I need some help.
When I plug the drive in my computer will no go past the post screen. It stops on the press delete for whatever, press escape for whatever and it won't go past that. I've tried different SATA ports, and different power connections but none are working.
As soon as I unplug the drive the computer has no problems firing all the way up.
Should I just send it back for RMA?
Other suggestions?
"If I put my ports into AHCI and try to boot it doesn't work. It just holds on that very first black boot screen that shows your drives and you can press enter or escape. It won't do anything from there, I just have to restart and it does the same thing again. If I put the drives back into IDE mode or whatever everything works fine again.
Also, today I've gotten the drive to show up in windows, however I have to wait until the computer login process is at the password screen to connect the drives power connector then log into windows and it will show up in my computer screen. Now, when I try to install windows on the drive it doesn't show up in the windows install choice of drives. "
Other suggestions?
