New Socket A mobo with IDE RAID?
MegaRouge
I'm looking for a new Socket A motherboard (nforce 2 preferred) with onboard IDE RAID. I have two 80GB IDE drives that I run in RAID 0 on my current board. Every board I see today has SATA RAID, but none have IDE RAID that I can find. I have no interest at all in SATA right now. Are there IDE to SATA converters I could use that I don't know about? I'd rather not get a PCI RAID card. Any advice would be appreciated.
Unfortunately, there is no native motherboard-chipset-integrated IDE (P-ATA) RAID solution that ever existed. Every one of the IDE RAID solutions ever made use complicated setup procedures, since they all use separate PCI-based controller chipsets. And using any of those controller chipsets is equivalent to using a separate low-cost PCI IDE RAID card.
I'm a little confused now. My current socket A motherboard (Gigabyte 7VRXP) has onboard IDE RAID. I'm looking for another, newer motherboard with an nForce 2 chipset with onboard IDE RAID, not onboard SATA RAID. From what I can see, it appears all motherboard manufacturers moved to SATA RAID exclusively in the last few months and I can't find one that has onboard IDE RAID.
The DFI Lanparty NF2 Ultra has P-ATA raid.. at least the first version of it does... not sure if Rev2 has it.
Revision A does have PATA RAID. Revison B does.
When they say native PATA RAID, they mean one thats running off the Via or nVidia chipset. The Gigabyte board you have does have PATA RAID, but it's through an extra Promise PATA chip.
Gigabyte's NF2 boards have PATA RAID, btw, as well as Albatron IIRC.
