New SN25P system just died
While I was playing HL2, my new self built system (this: Shuttle SN25P | Athlon 64 3700+ San Diego | Corsair 2GB DDR Value Select PC3200 CAS3.0 Kit (2x1GB) | BFG GeForce PCX6600 GT OC 128MB DDR3 TV-Out/Dual DVI | Western Digital Raptor 74GB 10,000RPM SATA 8MB Cache | Shuttle CR40 Double Layer 16x DVD Writer (Black) | Sony 3.5 inch Floppy Disk Drive (Black)) just died, without any warning. Now it won't do anything - all I get is one orange flash when I turn the power on at the back, and one blue flash when I press the power on button at the front? What can I do? Please help!
reset the cmos. little button on the back of the case. then take out the mem and try one stick at a time as mem sometimes goes bad quickly and one stick could be bad. if that doesn't work...well then it could be the power supply is bad or the cpu/ video card came loose or fried somehow.
The system will power up if I remove the video card, all the fans will blow (but theres no beeping sound or any other sound). If I reinsert the video card, its dead again. Is the problem more likely to be with the card or the mobo/case?
