Hello HardForum, first of all I must tell I am very happy founding this forum because I have found really sweet systems here.
Here are my wish:
1. What will you be doing with this PC? software virtualization in VirtualBox (many VMs at once), movies and some medium rezolution games (I don't want separate video card!!)
2. What's your budget? <800 euros, cheap as posible
3. Where do you live? Spain
4. What exact parts do you need for that budget? Case,PSU, CPU, motherboard,much ram,only 1 ssd without hdd, 1 good CPU cooler
5. If reusing any parts, what parts will you be reusing? All new
6. What specific features do you need in a motherboard? 1 HDMI port and to be cold as posible
7. What resolution output do you need? fullHD
8. Does this system need to fit into a particular space? I want to the case to be as small as posible
9. How comfortable are you with custom case design/modification and electrical wiring? I want all out of the box, I don't want to modify case and other components.
10. How important is the noise/silence of this sytem? I want to be very quiet if it is posible
11. How mobile does this system need to be? I don't want WaterCooling, I think this is a very dengerous job for electronic parts
12. Do you already have a legit and reusable/transferable OS key/license? Windows 7 Ultimate 64bit
13. When do you plan on building/buying the PC? In a couple of weeks.
I'm thinking at intel i7 2600 processor and at Asus P8H67-I Mini ITX motherboard. In the future I don't want to overclock the system and I don't want a separate video card. I would be happy with Intel HD3000 or other integrated card which supports HD playback.
I want a small and cold case. Please help me to build a system
Here are my wish:
