new sli system
b4ds33d
ive had my current system with a single ati card, but just got 2 xfx 6600gt's and set it up for sli. i uninstalled the drivers with driver cleaner, took out the ati card and installed the 2 cards, installed the sli bridge and plugged the monitor cable into the top card, left hand dvi plug. i then installed the latest forceware driver, rebooted and everything works. all except the sli part. how do i enable it? there are no prompts that pop up like the slizone website stated. is this something i do in windows? plaz help and sli noob!
nosli jumper. im looking at the mobo manual and it says you have to enable sli through the nview tab in the nvidia control panel. i dont have the nview tab....ive installed the latest forceware driver.
I think you have the latest forceware drivers, but did you also download or install the forceware programs? Kind of like Nvidia's version of ATI's Catalyst
i thinki have a mobo issue. it wont post now with the cards in sli config, but will work fine if a only have 1 card in. strange...
