Model #: ST75F = Newer Model, aka "Stridar"
http://www.newegg.com/Product/Product.asp?Item=N82E16817256009
Model #: ST75ZF = Existing Model, aka "Zeus"
http://www.newegg.com/Product/Product.asp?Item=N82E16817256006
Quick Review:
Pros: I just bought the new 750w offering, the ST75F "Stridar". It has a larger 120mm fan, it is modular, it has 2 more PCI-E connectors, 2 more SATA connectors, and 2 more standard connectors (the manufacturer's website mis-reports these, but newegg had it correct). It has native aux 4 - 6 - 8 pin modular connectors that do not require the use of an adapter like the previous model. I am no expert on the internals of a PSU, however the massive heatsinks covering every inch of the interior of the PSU appear clearly visible through the case's perferations. Better yet, on newegg it was cheaper -- seemed like a no brainer.
I've been running this for a week and I have no serious complaints; I really like this thing. My previous 550watt PSU handled my OC'd core2duo and 8800gtx just fine, so this model should handle SLI and then some. It doesn't have as pretty a paint job as some of the Enermax's I've purchased, but the semi-gloss black "works". I particularly like the black power connectors on the end of every cable. It has 24pin main and an 8pin aux, just what my evga 680i wants. However, the newer 24pin connector is not a 20pin+4pin, so it most likely will not work in the older 20pin mainboards.
Cons: If I had to pick on anything, it would be that this "modular" PSU has all of the SATA connectors on one modular connector to the Unit. So if you want to hook up a single SATA device -- you need to plug in all 6... However, this seems to be a trend with many other modular PSU's as well. Also regarding the SATA modular cable, it is not fully cable wrapped like all of the other connectors on the unit.
Overall: Good brand, good wattage, active PFC, Quad 12v rails, lots and lots of connectors, bells, and whistles.
I would highly recommend this PSU.
Quick Review:
