Specs are: Shuttle SB65G2, P4 2.4C@3.0, 512MB kingston value ram, ATI 9250 PCI card. I'll be listening to music while surfing the net and downloading the cs: source update then all of a sudden it'll restart. cpu temp is 31C and case is 40C.
I am going to say it is because of the overclock. Not heat related, but power related. Have you up the vcore to the processor, are you voltage rails stable? Lots of things to consider with a big overclock like 600 mhz in that small of system.
It really sounds like a power supply issue. If you mention that it only happens now when you install something. For example your hard drive and cd rom are running full speed uses excess power. I would say about the only thing you could do is swap for a better power supply. I do not know how that works in a shuttle, since your options are liimited.
