New SG03 build guidance
reswob
So I would like to hear your opinions on some hardware I need to purchase to complete my first SFF build.
Right now, I have a SIlverStone SG03B case. I plan on getting a Q6600 G0 (Yes, this will be a toaster). As for the mobo, I think I'm gonna get a G33 of some sort. I don't know when the G35's or x38 variants are coming out. For cooling I think I'm kinda stuck having to use the NT06 Lite.
I'm not sure what type of ram I want though. Ideally, I would like to hit 400FSB. Should I get some cheap XMS2 DDR800 or something similar?
My suggestion is doing the fan mod on your 620HX and attaching an 80mm fan under the NT-06 blowing up, that should help your temps a bit.
Rumors is the the matx version of the P-38 probably wont be seen till Q1 2008. Kinda depends on when the P-38 atx mobos actually get out.
umm i think turning the psu to the out side vent, and getting a cnps 8700 would be a good idea with two 120s in front and a pci fan on the top and the very bottom.
