New SFF - Confused - Need Help!
Sup all. I need some help here....I just got a SN85G4 V2 w/ a SATA (1) hard drive. I am very confused about which driver(s) I need to install ....
On shuttles dl page there are 2 possible drivers...
1. RAID Driver Disk
2. SATA RAID Driver
I am only running 1 hard drive so I won't have a RAID setup.
Thanks....
You will not need either if you are not running a RAID setup.
I have 3 HDD's, all SATA and none are RAIDed. For the ICH5R SATA (I'm using an Asus P4C800-E D), I don't require drivers at all. For the ones on the onboard SATA controller I require a standard driver, but not a floppy.
Hope that helps
