Hi all,
Looking to build a small home server / media PC for storing and viewing my multimedia. It needs to be compact and accessible by 3 desktops and a couple of laptops (at most 2/3 at a time). I'd also like the option to connect directly to a 37" HDTV (DVI or HDMI). Box has to be quiet and preferably low power. Will probably run Linux or similar OS initially, but would like the option to switch to Windows at some point.
I live in Ireland so bear with me on the links to UK sites and pricing. I'm aiming for a price point somwhere around £400-£500 without hard drives. But happy to let this slide a little either way.
In order to keep the size down, I've opted for a mini-itx form factor. I've done a (small!) bit of research and my parts list looks as follows:
Case: X-Case atomic home server
Motherboard: Zotac 9300 ITX WIFI
CPU: Intel E6300 Dual-Core (45nm wolfdale chip)
RAM: Going for 4GB (2x2) 800MHz Ram. These seem like good value, but open to any suggestions.
HDDs: WD Green 1.5TB x 2
DVDRW: Haven't picked one out yet, but just looking for something quiet and reliable. Any ideas would be welcome.
To use both HDDS and the DVD Drive I'll either use the external e-SATA port or maybe a PCI expansion card for further ports.
I'd appreciate any suggestions or comments. feel free to link US sites - I can try to source the parts locally once I know what I'm looking for.
