New SFF Build: LL PC-TU100?
FSMITH010
This is my first post so I thought I would do things the official way, I hope the long bit of text doesn't prevent readability.
Main Questions:
PSU: Silverstone regular or gold PSU the best option?
Video Card: Maybe a 7.5" option, a 8"ish option and a 9.5"
Cooling: Can I use an H60 or is there something better to use in this application?
Case:
Initially was thinking SG-05, also considered Lian Li Q27, Q07, Q11
Then found this just came out. I would remove the handle..
Lian Li PC-TU100
Lian Li TU100 Video Presentation
PSU: Silverstone 450w regular or modular? I would be more concerned about the wires than the fan noise
CPU: 3570k
Motherboard: Arock Z77 1155
Cooling: I would put a H60 if I can fit it, or whatever else would work better.
RAM: 8-16GB
ODD: none
HD: one SSD
VGA: For a 190mm limit I have this: PNY 650 Ti Boost 2GB
Manufacturer says 190mm cards fit, some articles say 200m (7.8"). The front USB panel (and possibly the fan) prohibits a longer card.
If I can move the front panel I think a longer card can fit in. The depth of the case is 9.8" (250mm), so possibly a larger card might fit. Any suggestions?
with GTX 670 Mini installed
Thoughts, suggestions?
Zotac makes short GTX 660 and 660 Ti, around 191mm long. They're pretty cheap compared to the super expensive Asus GTX 670 Mini, for much better performance than a GTX 650.
A 650 ti Boost is close to a 660 right?
What about Zotac? Are they decent for video cards?
Since there is no ventilation at the bottom of the case will these cards get too hot?
you can always *make* ventilation at the bottom of the case :D
I was thinking about that, and flipping the case upside-down so the hot air exits up. Is having your video card at the top of the case bad, I don't see many designs like that.
Alternatively add some feet on the bottom so it has room to breath?
From the reviews I've read (like on Anandtech), this case has airflow issues. I wouldn't remove the front fan if I were you.
Thinking about putting a 140mm there and running the H60 where the ODD is supposed to be, or something like that using that space for cooling apparatus. Maybe just a pull fan.
I wouldn't flip it if I were you -- you never know what falls on top of a computer case :p That and your hot air dead-zone is going to be the back of your GPU...
I went with the 7/8" black grooved case feet from MNPCTech with my build to give my video card inlet access to cool air.
what about two 120mm or 140mms on the front since I won't be using the odd, then using the stock cpu fan?
Any ideas on a optimal cooling setup?
Should the psu exhaust on to the motherboard?
There is only a 60mm clearance for a cpu cooler.
Hi lvyelion,
I'm perplexed by the positions of the disks and usb front (but the monkey you know ...she is stubborn) hope I am wrong.
In some photos seem to see one ulterior space between the front and the internal fan, you might think about putting a fan there and put the radiator in place of the original, or if space allows, try to use two of them, even slim ...but it is all speculation until we'll have it at home.
Probably (as on many LL cases) you would use also a good air cooling
When it comes to the TU100 & TU200 I say just get a PC Q08 and mod a handle on it and then you'll have the better of all of them. Just my own opinion though when it comes to the TU 100/200 series. :D
If you've got piles of cash laying around, I could part with Neutronium... nahhh :D
