So my setup is complete except for one thing... my vid card which has me asking some questions....
So I wasnt able to buy enough ramsinks initially (thought only needed 7 instead of 14) and have my block on with only 7 heatsinks on... Heres the question... Evga Precision shows the GPU at 51 (without side case fan on) and 48 with it on blowing over the ram sinks at idle... Once any load is put on it goes through the roof, I stopped it at 80 but it was definately going to climb higher. So at this point the question is how is the GPU temp measured? Is it just the GPU which is under a water block or does it use the ram temp in some way shape or form?? The ram is definately getting pretty hot (checked by finger) but its odd that the GPU is whats reporting this... I figure even with a bad mount or to much grease theres no way I should be running 80C + and 50 idle.
