Myself and two other co-workers are doing a group server build within the next month or two. We have done some research and have spec'd out a few paths for the hardware but I did want another set of eyes to glance over what we were thinking.
All three machines will be servers. They are looking to build a media server/plex server. They want to stream their content to various devices. At most, each server would have a max of 3-4 stream at once (rare instances).
My server is a little different. I have a Ubiquiti setup so I would need the server to also be able to handle running the Unifi controller. Therefore, I would want my server to handle at LEAST the following three roles:
In the long run, I may want to run two VMs (Win Server 2012 and maybe linux) to mess around with
The lower the better. Honestly, I’m looking at a build cost of $350-$400 without storage
USA, Newburgh NY. We have a micro center 45 min away.
Case (mATX or mini-ITX)
CPU
Mobo (mATX or mini-ITX)
RAM
PSU
None
6) Will you be overclocking?
No
N/A
Within the next month or two
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
USB 3.0, at least 6xSATA3, On-Board video wouldn’t be bad.
Yes, we already have OS licenses. 64-Bit Win Server 2012
The guys are leaning towards mini-ITX because they like the SFF cases. I, on the other hand, and nervous in dealing with such a small enclosure for future growth. Therefore, I was looking at mATX as well. Therefore, we are really up in the air on which solution to go with.
I started doing some research and came up with the following two mATX builds for you to look over. The build features 8GB of RAM. I know with ESXi and multiple VMs, I would need more. This is just a starting point.
A few questions:
1. A lot of users on the Plex boards really like the G-series chips. Are these really enough for streaming? Most of the streams will be direct-play, so there will be minimal transcoding.
2. If the chip is enough for streaming, will it be able to handle running 2x Win Server 2012 VMs? Or am I better off with the i3?
3. I would assume a 500w PSU should be more than capable of handling the server with 6-ish drives, no? The OS drive will most likely be a 90-128B SSD.
Finally, we are also open to AMD based systems. However, I've been out of the AMD game too long so I don't know what they have to offer at this point.
Thanks!
- Plex Media Server
- UniFi Controller
- Be able to run backups of client machines
- I would possibly run a mix of two VMs to handle the server listed above. For example, a Windows Server 2012 VM for Plex and another for the Unifi Controller and backups, etc. I would run ESXi. If this isn't feasible, I will just run a dedicated Win Server 2012 box.
CPU
RAM
PSU
None
No
N/A
A few questions:
Thanks!
