New SB75G2 Shuttle. Problems transferring large files over the network.
I just built a bare bones shuttle SB75G2 system. Specs:
-P4 3.2C
-2x 512mb Mushkin Level II Black 2-2-2 Special (ddr400)
-2x 36.7gb 10,000rpm WD Rapters in Raid 0
-ATI 9800xt
After building, I ran into some ram issues. BSODs and errors during windows installation. After checking the bios, I realized it was configuring the ram inccorectly. Set the cas latency to the correct setting, set the voltage to 2.75, and turned off Bios Caching. Everything posted and installed fine after that.
After getting everything installed, I started installing games. I imaged all my games on my old computer so I didnt have to carry the CDs around to LAN parties. I start copying images over and begin installing. Every one of the images CRC failed during installation. Ive had this problem before (when I lived at my parents house on their home network) and they just kind of disapeared, but, this being a new computer, I started to freak out. The situation gets weirder that I can mount the image over the network using daemon tools and it installs fine. The same thing happens with game patches. If I copy them from another computer it CRC fails, but if I run it on that computer or download it from the internet, it runs fine.
Here is what I have done thus far:
- Updated the chipset, raid, and onboard peripherals (except for the gigabit lan driver, since the one on the shuttle site wont work on either mine or my buddies SB75G2)
- Switched network cables (cat5e, but no one else at my house is having a problem, and one of my roomies has the exact same shuttle with different components)
- Switched ports
- Tried transfering over firewire with the same results (BAD CRC).
- Ran the Data life tools in both windows and off the bootdisk with no errors detected
- Looped memtest86 for ten and a half hours (on standard test mode) and got 0 errors out of 77 tests.
The only thing I can think of is a format reinstall, but I wanted to make sure there wasnt something I missed.
Thanks =)
