I'm having trouble getting a new SATA drive to display in Windows with my GA-8INXP mobo. I have XP (updated, etc) installed on a 36GB SCSI drive (my boot drive). The SCSI controller is an Adaptec PCI card. I also have 2 IDE 80GB drives setup in a RAID 0 config on the onboard Promise controller this Gigabyte mobo has. Now, this Gigabyte mobo also has an onboard SATA controller (not the Promise one either, seperate controller, a SI 3112).
I'm trying to hook up a WD SATA 120GB HD. When I do this and boot into Windows, the drive is there in the device manager, even shows it is running in DMA 5 (though I thought it should be in DMA 6?). Says it is working properly as well. But I don't see the drive as a drive letter - nothing is there. In my BIOS settings, I have the SATA controller enabled (it's also in the device manager and Windows installed it when I enabled it in the BIOS), and it is configured for BASE funtion, not RAID. I have tried different SATA cables, tried both SATA slots on the mobo, even disabled the Promise RAID controller. Nothing works. I bought two of these 120GB HDs, and both are doing the same thing, and I've tried 4 different SATA cables. The drive shows up as a Hard Disk in the device manager, right name and all, but doesn't show up as a drive in My Computer. Diagnostics on the drive show both are working fine. So does anyone know what the problem could be?
