I just recently purchased the newly released 2232BW Monitor from Best Buy a couple days ago (Same as 226BW but with a different look) and when I try to install the driver for it I get a pop up saying "Can't find specified file" and then it closes. However after trying to install the driver it says in my display settings that i'm using the 2232BW but I can't adjust the properties. But as soon as I restart the computer the monitor display reverts back to "Plug and Play Monitor" I have tried the driver from the CD and downloading it directly from Samsung's website and I get the same result.
Another thing that is odd is that it came with MagicTune and I can use that sometimes. I say sometimes because ever now and then when I try to use it I get a popup saying "This monitor does not support MagicTune" then I have to restart the computer and then MagicTune works fine. Do I even need to install a monitor driver? Anyway any help I can get would be great. Thanks.
Monitor Link: http://www.bestbuy.com/site/olspage.jsp?skuId=8439442&st=2232bw&type=product&id=1183160137115
