This is for home use... I'm thinking about going with a Mikrotik RB2011UAS-2HND-IN. Looks nice, especially since it has 5xgig and 5x fastethernet ports, plus POE on select ports if I decide to add a security camera or different AP in time. Does anyone have any experience with this particular device? I'm looking for an item that is more powerful and of higher quality/reliability than your standard Dlink/Belkin/Linksys Residential style devices. The QoS on my current 6 year old DLink doesn't work that well and even with bandwidth priortization things lag when someone is downloading, plus it needs to be rebooted when used heavily in my home of 14 devices, so I'm sure it won't be reliable at all with the additional load of 12-18 additional users.
I also have a few items that I'd like to accomplish:
Outside of the Mikrotik, is there anything else that fits the bill for arond $120ish?
The only thing I'm slightly concerned about is this product looks harder to configure than a standard home router, which being a more professional level product comes with the territory. I've never configured a device that needed as many configuration steps to get things working. Is there another device that's easier to configure that will fit the bill, or should I bite the bullet and spend the time figuring out how to config the Mikrotik device?
- Bandwidth Shaping and limiting by IP. Since I'll be hosting LANs I'd like to limit each IP to no more than ~15% of the Internet connection's bandwidth. This should help keep websurfing, etc. from impacting gaming. It appears as if RouterOS can do this http://khmercomputertrick.blogspot.com/2013/03/basic-internet-sharing-with-bandwidth.html I have a 60mbit connection so it looks like I should just be able to set it to ~6mbit max per user for the LAN party/wifi sides and higher for the private home network side.
- VLANs: I'd like to separate my home network from the 24 port switch that will serve the gaming area (large unfinshed 30' x 20' room in basement with 3x20amp circuits) for security reasons. I'd also like to separate my wifi APs to their own VLAN as well, again security.
- Something Robust that will easily handle the load of 50ish devices connected.
- Something Reliable, I'm sick of rebooting my DLink Router every 7ish days.
