New Rig
Drop the WD hard drive for a Seagate which is around $90 or get a 400gb Samsung for $110. If you want to have any chance of playing oblivion at decent settings get a x1950pro for $200. For the power supply get a 550W Seasonic instead as its the same price and higher quality. For the ram get some Buffalo Firestix for around $250 IIRC because they overclock nicely. If you want to have any chance of getting a high overclock on that e6600 get an aftermarket cooler if not drop down the e6400 and overclock that with either a stock or aftermarket cooler.
Sweet, I'll check that out, thanks.
Skip the Enermax PSU; Try the Corsair HX 520 or 620, or the Seasonic S12-EP 550 or 650. They're better options than the enermax, unfortunatly.
I agree with b0b and bbq. For the ram, you could also go with the Patriot sticks that also use the same Micron ICs as the Firestix. Both are under $250 and can OC better than the Kingston Hyper X DDR2-800. What size monitor do you have? If you don't need SLI, go for a P965 Express board instead, like the P5B-E or DS3.
I have a Dell 2001fp, so it's a 20" display... I'm thinking about going with an 1080i HDTV eventually.
I made some updates. I definately want to wait a while, especially with the price of the mobo.... But here's the new list:
http://spreadsheets.google.com/pub?key=pSHOIT5SR-V6C43KyVZfqNQ
Any particular reason you're going with a $420 mobo? You do realize that you'll be spending more money on the mobo than your CPU or Vidcard, right? ... and I thought my DS3 was expensive at $125, lol. My previous most expensive board was my DFI, for $105, hehe. I don't really see a point in getting the striker over any of the cheaper 680i boards.
The reviews are very good for it, I dunno, no real particular reason. I'd be open for suggestions on ones that would do the same with a lot less bling. I want mainly reliability, and the nForce chipset.
