New rig won't power up
jstenuf
I have a Stacker Evo, EVGA 680i MB, Enermax PSU, and Nvidia GPU.
The power supply light is on the PSU and shows no fault, the light on the MB is blue and the power switch on the Stacker is blue, but when i press the power switch on the Stacker nothing happens. I thought It might be the power switch on the Stacker, but I do not know how to verify this. Any help would be appreciated.
Reseat the CPU, i have seen this b4 when the cpu is not installed properly..the lights are on the psu and the mobo but the thing wont turn on...IIRC i think the fans spin for a split sec and shut down..also can u plz post what hw u have
May be a stupid question but: Are you sure you have connected the case frontpanel correctly? Have you doublechecked all connections?
1)Re seat the ram
2)Re seat the Cpu
3)have the latest bios too support your chip? (happened on my m2n-e with my opty)
Disconnect front panel.
1)Take a screwdriver and make contact between the POWER pins on the motherboard with screwdriver.
2) Reset Bios using jumper, try again.
If it doen't boot and everything is properly connected (PSU, Ram, CPU).
3)Remove motherboard from case: set on mobo box, put in ram, CPU and GPU. Connect PSU. Connect Keyboard and then power up using the screwdriver as before.
If it boots it means you have something misplace in the case which is shortcircuting your Mobo.
If it still doesnt boot, one of those components is DOA or flawed. U have to replace parts one by one to see what's fudged.
There is a slight chance your Bios doenst yet support your CPU or GPU, this is rare but if this is the case you need an alternate one to load your mobos latest bios.
Lastly, if you do not have a any experience, SEEK HELP, so not to fry your system....
Good Luck!!
Thanks to all that responded, it is appreciated.
I have checked and doubled checked all connections, but everythings appears to be connected properly. I will try all recommendations and report back.
I have a question: what RAM are you using? The eVGA 680i board is notorious for not playing nice which requires high voltages.
