New Rig what do u think?
hey im new to the forums been reading a while though....what do u guys think about this rig... basically in gonna use it to encode dvds,surf the web and encode music and mild gaming but i want something fast...actually alot of multitasking...would this be a fast system and good for running multiple apps at once?
Antec Performance I P180B Black 0.8mm cold rolled steel for durability through the majority of chassis 1.0mm cold rolled steel around the 4 x HDD area ATX Mid Tower Computer Case - Retail
Model #: P180B
Item #: N82E16811129017
Return Policy: Standard Return Policy
In Stock
$129.99 -$15.00 Instant $114.99
ASUS P5W DH DELUXE/WIFI-AP Socket T (LGA 775) Intel 975X ATX Intel Motherboard - Retail
Model #: P5WDH DELUXE/WIFI-AP
Item #: N82E16813131025
In Stock
$269.99 -$20.00 Instant $249.99
eVGA 512-P2-N635-AR GeForce 7950GT 512MB GDDR3 PCI Express x16 Video Card - Retail
Model #: 512-P2-N635-AR
Item #: N82E16814130061
In Stock
Mail-in Rebate
$295.99 -$10.00 Instant $285.99
FSP Group (Fortron Source) FX600-GLN ATX12V/ EPS12V 600W Quad. SLi Power Supply - Retail
Model #: FX600-GLN
Item #: N82E16817104014
$139.99 $139.99
Intel Core 2 Duo E6600 Conroe 2.4GHz LGA 775 Processor Model BX80557E6600 - Retail
Model #: BX80557E6600
Item #: N82E16819115003
Return Policy: Processors (CPUs) Return Policy
In Stock
$315.00 $315.00
G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400PHU2-2GBHZ - Retail
Model #: F2-6400PHU2-2GBHZ
Item #: N82E16820231065
$339.99 -$40.00 Instant $299.99
MITSUMI Black 1.44MB 3.5" Internal USB 2.0 digital card reader with Floppy Drive - OEM
Model #: FA404M BLK
Item #: N82E16821104104
$18.99 $18.99
Western Digital Raptor WD740ADFD 74GB 10,000 RPM Serial ATA150 Hard Drive - OEM
Model #: WD740ADFD
Item #: N82E16822136033
In Stock
$149.99 $149.99
Seagate Barracuda 7200.10 (Perpendicular Recording) ST3320620A 320GB 7200 RPM IDE Ultra ATA100 Hard Drive - OEM
Model #: ST3320620A
Item #: N82E16822148139
In Stock
$94.99 $189.98
Saitek PZ30AU Black USB Wired Standard Eclipse Keyboard - Retail
Model #: PZ30AU
Item #: N82E16823175103
In Stock
$44.99 $44.99
SAMSUNG 225BW Black 22" 5 ms (GTG) Widescreen LCD Monitor with Height Adjustments - Retail
Model #: 225BW
Item #: N82E16824001083
Return Policy: Limited Non-Refundable 30-Day Return Policy
In Stock
$379.99 $379.99
RAZER Plasma Diamondback RZD-1600P Blue 7 Buttons 1x Wheel USB Optical Mouse - Retail
Model #: 897126000850
Item #: N82E16826153104
Auto-Notify
$49.99 -$8.00 Instant $41.99
NEC 18X DVD±R DVD Burner With 12X DVD-RAM Write Black E-IDE / ATAPI Model 7170A-0B - OEM
Model #: 7170A-0B
Item #: N82E16827152076
$31.99 $31.99
ZALMAN CNPS9500 LED 92mm 2 Ball Blue LED Light Cooling Fan with Heatsink - Retail
Model #: CNPS 9500 LED
Item #: N82E16835118223
In Stock
$63.99 $63.99
Subtotal: $2,327.86
Select All - Select None
very nice build but if you only going to do mild gaming i would suggest you lower the 7950 to something around a 7600gt. cheaper and play most games.
also, i would suggest to get a power supply that isnt that good. its kinda overkill for me
my .02c
Not a bad build.
personally I'd drop the raptor...but overall not bad.
slight overkill on the power supply...
and like previous post said.. i'd go for the 7600...
yea i was looking at the 7600gt...will that run the 22 inch samsung lcd ok at the highest resolution... getting the raptor just for the OS and the two 320gb Seagates probably gonna run in RAID.Also can u recommend a good power supply then??
I bought an Antec Tru Power 2.0 550 Watt power supply from newegg and have been very pleased. Nice and quiet.
i got a 20.1" widescreen and a 19" lcd running form the 7600gt no problem, i highly dought that your monitor will make any problems arise
