New Rig: Suggestions, Comments, Questions
abudhu
Good Morning, Afternoon, Evening.
I have begun to spec a new system and as such would like any feedback (good or bad) and perhaps an answer to one or two of my questions that follow.
While I have done research on the subject of Inte Duo versus AMD, I just do not fancy the Duos. I have no plans to overclock my machine, and would just like a simple down and dirty gaming rig. Past experience has led me to favor AMD over the years. The recent price drops in the X2’s also leads me to favor the AMD solution currently as well. As such, if suggestions (which I welcome with opens arms) would refrain from changing the CPU that’d be fantastic.
My Current System Rig is in my Signature for comparison purposes.
Without further Ado:
Budget: 1,000-1,200. Preferably I would like to be SUB-1000. So please, the 1,200 is an upper-limit that I’d rather NOT reach. Currently my specced machine comes in at around 1,027 pre-shipping.
CPU: AMD Athlon 64 X2 5600+ AM2 Socket
Price: 182.90
Motherboard: MSI K9N4 Nforce 500SLI
Price: 85.99
*Question 1
Memory: Corsair XMS2 2GB (2 X 1GB)
Price: 159.00
Video Card: EVGA GeForce 8800GTS 320MB
Price: 279.99
*Question 2
CPU HeatSink: Zalman CNPS 9500
Price: 48.99
*Question 3
PowerSupply: OCZ 700W
Price: 149.99
Case: Antec P180B
Price: 129.99
*Question 4
Question 1:
Read a few reviews about it and it seems to be a solid board capable of overclocking (if I decided to go that route). Your opinions? Trying to stick with a “cheap” board. While I would like to SLI in the future, it is not a true factor. To elaborate I would say, SLi is a feature I wouldn’t mind having but could live without. With that said, would you recommend I go to a single PCI board and save some money? If so which would you recommend?
Question 2:
Always heard great things about EVGA. Unfortunately I have not kept up to speed as I would have liked to with the current graphic market. My major question here would be does the 320MB make a large difference in performance to its big brothers with 512+? I really don’t want to break my budget on the card, and if this is a top-notch performer then I will stick to it.
Question 3:
Heard the Heatsink is a danger to put on as its sharp as hell. Anyone have experience with it? I am also concerned with its weight. Newegg tells me its dimensions, but not its weight. Seems darn heavy. My other question would go along with the board itself, in that will it clear the memory? I tried to put all the pictures in photoshop and scale them correctly, alas I couldn’t quite figure it out.
Question 4:
The case, the biggest woe. So many minor but important questions. 1) Will everything fit? Once again I tried taking the images off Newegg and putting them into photoshop. However, I seem to suck at figuring out scaling measurements and couldn’t get it work well with all the parts. 2) Will the 8800GTS fit and have clearance room? I did some research on the web and it seems users who have bought this claim the video card can fit, but, I still want a more firm answer.
Edit 1:
Thinking of changing my Mobo to: ASUS M2N-SLI. Thoughts? Seems to be a more stable, high-end board. Still keeps me under 1100 as well.
First suggestions is to trade out the OCZ power supply for the Corsair 620HX. It's a better quality PSU, and less expensive (saves you about twenty bucks). It's always good to save some $$$ :D
I'm assuming you'd like to be able to store things on this machine, so something like a 250GB 7200.10 for $67 should fit the bill. There are larger variants available, should you find it necessary to go for more storage.
Question 1: That board should be fine for some relatively restrained overclocking. Don't expect to crack world records, but it should provide a stable platform with some decent overclocking options. If you're able to up the budget by about twenty dollars, consider some of the offerings with 570 SLI and 590 SLI chipsets.
Question 2: eVGA is an excellent brand of nVidia videocards. I have personally dealt with their RMA department (during the 7900 fiasco) and had my new card overnighted to me. I simply put the broken card into the box the new card came in, slapped on the supplied shipping label, and dropped it in the mail back to them. They've got a lifetime warranty which covers aftermarket heatsinks and overclocking. Check out [H]'s review of the BFG 320 OC to see how the 320MB version compares to the 640MB version here.
Question 3: You shouldn't have any issue using the 9500 on your board. Consider cheaper alternatives such as the Scythe Ninja for basically the same performance for less money.
Question 4: I have the P180 (not the black version), and it will have plenty of room for an 8800GTS. It's an excellent case with good quality construction and ample cooling.
I would get something other than the Zalman. The Zalman heatsink/fans are not that great for their price compared to what else is available. You can get the Scythe Ninja Plus RevB for less or if you want to do heavy overclocking then I would get the Ultra 120 Extreme or Tuniq Tower with a 120mm fan.
make sure the ram you get works with the board you get. thats the biggest problem i've had with am2 systems... ram compatibility. make sure the board can support more than 1.8v vDIMM. Yes, even corsair ram doesnt work on some boards.
I have made the desision to go with Corsair HX 620W for my Powersupply instead, and I am changing my motherboard to the ASUS M2N SLI.
To those that have answered already, thankyou. I have verified my memory will work with the motherboard at the rated speeds. I have chosen to stick with the Zalman as it still seems to be one of the better Fans for the price. I did look up the Scythe Ninja Plus RevB as suggested. Seems great, but I can't seem to find a standard vendor (I.e Newegg) that has it. I also looked up the Thermaltake Ultra 120, and it seems to require an addon for AM2 compatibility, which would add on to its price. :-\
I am planning on pulling the trigger and purchasing the parts when the weekend rolls around. Any other tips/advice would be greatly appreciated.
A question I just thought up:
Question 5:
I have been looking at the vendor known as Club IT. There website doesn't present itself as "We won't steal your money" yet, according to PriceWatch and various other websites they don't seem to be bad. I suppose its just their ugly layout. In any case, has anyone had experience ordering/returning from them? If they aren't worth the trouble I will gladly pay a little more and go with "Trusted" sites such as NewEgg or ZipZoomFly.
You can find the Ninja on Newegg here.
I'm pretty sure I've ordered things from ClubIT before, and I didn't have any complaints. However, I have never had to deal with their customer support... In my opinion it'd be a good idea to stick with newegg to have the assurance that if something is wrong with your order that you shouldn't have a problem exchanging it.
Put in the orders today, should be here by Friday.
I would just like to Thank those who responded. You helped adjust my choices and I should have a new, darn good Computer coming in any day now.
Thanks mates.
/Updated Sig...well because I could =D
