New rig running slow
bordes
Hello I just built a new rig and everything is running fine except the video card. It installed all the latest drivers and set my monitor at a good resolution. However, when I try to game it's completely lagged out.
Two problems I think it could be is the PSU might be too low or perhaps I have to turn off one of the dual processors. I have never used dualcore technology so I'm not sure.
My Specs are as follows:
AMD Athlon 64 X2 6000+
EVGA 8800GTS 640 MBs
ASUS M2N-SLI Deluxe AM2 NVIDIA nForce 570 SLI MCP ATX AMD Motherboard
430 WATT PSU
X-FI SOUNDCARD
320 GIG SATA HARDDRIVE
ONE CDROM
Has anyone experienced this problem before? The video card recommends 420 Watts of power, but the motherboard recommends 600. Would turning a processor off, allow my computer more wattage (keep in mind it might not be the power at all)?
Also can anyone tell me any other problems they think it might be?
Thanks
What model PSU is that? Whay games are you trying to play? Is your CPU usage at 100%?
My new builddone about 3 weeks ago is almost the same computer but a different MOBO, and I used a Corsair 620W PSU and I've had no problems running pretty much anything i want on a new Dell 24" so It may be you PSU I would see if any of your friends have a higher wattage PSU that you could swap and test, or just upgrade it never hurts to have a higher quality PSU.
I cringed when I saw that PS. 18 volts on the 12 rail is asking, no, begging, no, demanding hardware problems.
Well like everyone here has said, you need to get a new power supply. The minimum you need for the 8800GTS 640MB is 24A on the +12V rail. That power supply you chose only has 18A on the +12V. So your 8800GTS is woefully underpowered and you may want to replace that PSU ASAP. Sooner or later that poor TR2 will die from the sheer power usage of the 8800GTS.
I recommend going with this power supply:
Enhance ENP-5150GH 500W PSU - $69
It has 29A on the +12V Rail so it should be enough for the 8800GTS 640MB
