New Rig Not Stable?
Chaos
I just bought a new rig made up of the following:
E6400 (Stock Cooler)
eVGA 680i
eVGA 7600 GT
G.Skill F2-6400PHU2-2GBHZ
I am currently running with VCore set to 1.0v in the BIOS (reported slightly lower in CPU-Z) because the Intel stock cooler sucks, and my house is extremely hot. I havn't tried to go longer, but I can run Orthos for 8 hours no problem at this voltage. RAM timings set to 4-4-4-12, with memory voltage at 2.1v. As soon as I set the computer up, I knew something was wrong. When I went to install Windows, it would run extremely fast, then stop, then fast, then stop. I eventually got that installed, and updated the BIOS to the latest version. This helped slightly, but I am noticing the same behavior in Windows now. Stop and go. Games run fine and do not exhibit this problem.
Also, my mouse seems to stop working (does not recognize clicks) periodically.
Anyone experienced this problem? Maybe someone could suggest a fix? I am upgrading my cooling next paycheck, so that is covered. Thanks in advance!
before you start bitchin' about the stock cooler use the Intel Thermal Analysis Tool (google it) to read your temps and if they're 70*C+ then you can complain about the stock cooler. It's clearly some other issue which I have no idea about.
I ran used Intel's TAT to measure temperatures. I ran Orthos for about 1 minute at stock voltage and my temps were already 65' on both cores! I did not want to take it further than that. I have tried reseating the heatsink, and it makes no difference, and I am using Artic Silver 5. As I said, my house is very hot :)
well you haven't seated the heatsink properly because I have my e6400@3.15ghz w/ 1.35v and it will usually load at 65*C-66*C and I'm currently in the middle of a hot Australian summer.
I think perhaps I haven't clearly addressed my issue here. I have solved my heat issue by undervolting the processor to slightly under 1.0v, and my load temps are about 45'C now. This has proven to be stable after 8 hours of stressing using Orthos. My actual issue is that Windows seems to "lock up", then unfreeze itself and speed along, only to freeze shortly after. Any suggestions regarding that would be much appreciated!
got all the drivers installed? it sounds like the cpu isnt getting enough power, so when your system tries to do something and the cpu needs more power, it has to "charge up," so to speak. though, once its got the power it needs, it runs fine. its just that split second where it would normally require some extra power to jump from idle mode, to processing mode. thats just my theory.
though, i really do agree with b0b. idle temps at stock voltage should be in the 30's, not much higher with an ambiant room temp of 80°F. my coworker recently got an e6400, and it wouldnt turn on because he didnt seat the hsf properly. he finally got it to startup, and called again because his idle temps were in the high 50's. i told him his HSF still wasn't on properly. he didnt believe me, but went with my suggestion to reseat again, and he finally got it right after a few tries. btw, he's using the intel stock thermal grease, instead of as5, and he now idles mid-high 30s, with a room temp of 85°. when i was building an e6400 for someone, it would idle high 20s - low 30s, because my room was a cool 65°F, lol.
