New rig need some oppinions
Eshelmen
Whats up all,
My current rig is in the sig, and definitely is time to upgrade.
I`m an AMD fan, so please dont try to push me to intel haha. And I like NVIDIA as well.
My current price for everything is roughly 1200 dollars.
This is including everything.
Mouse, monitor, motherboard, gpu, cpu, PSU, memory and harddrives.
This is what I`m thinking of getting so far.
Only thing I see outdated is the GPU, but I want two of them so they should be good right?
Logitech MX518 -39.99
www.newegg.com/Product/Product.aspx?Item=N82E16826104178
Western Digital Caviar Black 2 x 640 GB -149.98
http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319
Acer 21 inch monitor though was a good deal 149.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16824009175
Corsair 750 watt PSU this baby kicks up 60 amps- 119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006
G.SKILL PI Black 3GB DDR 3 ram. Not sure on these new technologies. But latest and most expensive of all typed rams. must be quick - 119.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231240
MSI 790FX-GD70 AM3 Motherboard"AM3"
Good Company I believe and the ratings are very decent. 174.99
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130223
XFX 9800 GTX x 2 "Little out dated, but two of these for under 300 = 269.98
And last the processor
AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 $245.00
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103674
So this is what I have as of now, about to order.
Anyone reccommend anything different?
I want a fast ass rig but all around 1200 thanks guys
You can't use SLi on 790FX chipset... Single 4890 or GTX 275 would be better value to your build.
I agree with lt_shiro: Regardless of the motherboard/chipset (more on that in a minute), one HD4890 or GTX 275 is a more practical solution than two 9800GTX cards. While those two cards may cost less, one high-end card is often easier to deal with than two mid-range cards and an SLI/CF setup.
If you decide to go the route that lt_shiro suggested, you could save some additional money by going with a different power supply. The Corsair TX750, though a good choice, is overkill for the above setup plus a single card. The Antec Earthwatts EA650 would work just as well and is also a bit easier on your wallet.
Additionally, the Phenom II processors don't gain any performance benefit from using DDR3 RAM. You could get a decent board that supports the processors and use DDR2 RAM, like the Gigabyte GA-MA790X-UD4P. A good DDR2 1066 kit, like the oft-lauded G.Skill set, is all that you really need.
