New Rig . . need AIR cooling suggestions
jnick
Heya guys!
I'm a couple of hours away from placing my order on my new rig:
AMD 64 3500+ (90nm Winnie)
MSI K8N Neo2 Plt.
BFG GeForce 6800GTOC
RAM is still up in the air.
I was wondering what cooling should I go with? The XP-120 is out, as thermalright says it doesn't fit. Even though some people says it does, I don't want to take any chances . . . I'm new to all of this OCing and Cooling.
Also, to keep in mind, I may try to OC the 3500+ winnie to at least 2.5GHz.
Any suggestions are greatly appreciated!
Jnick
Get the thermalright XP90 and put a 92mm Vantec tornado on it. Cranks out more air than most 120mm fans, and while it is rather loud (I have the 80mm version) You can hook it up to a fan controller and turn it down when you need quiet, and up when you need performance.
Thanks for the reply . . Is the Zalman 7000B-AlCu any good?
Thanks.
Jnick
Thanks.
Jnick
does it fit? i dont' see the neo2 plat on the MB list
K8T Neo2-F
K8T Neo2-FIR
Thoes are the only 2 i see
edit: i see it now, you just can't use it with the big arse video card cooler
