HybReD1234
- Aug 20, 2006
Well I just finished building my new rig a few hours ago. I didn't purchase a new HD because I figured I'd drag over my old 250GB WD that was split into 3 Partitions and leave my second HD which is IDE on the old PC and maybe reformat it later for other uses. So as I was dual booting a week ago I figured it would let me just split the two and each would work on their own. Yeah... if only.
The SATA WD: 1 Blank 15GB, a 20GB OS [XP SP2], and the rest was games & movies etc.
The IDE: 40GB with just the original OS and some random crap on it. It's old and useless and loud.
Anyway, after setting everything up I swapped hard drives and booted up all excited.... NTLDR is missing CTRL/ALT/DEL out. ...Crap. So I tried going back and forth and seeing what the problem is and if I had to take a blind guess... The SATA is relying on the IDE drive in order to boot. It boots fine on the OLD PC with both of them in. Without the IDE it get's an NTLDR error. So.... yeah. I reformatted the 250GB OS partition and reinstalled a fresh windows on it on the OLD PC [because for some reason I can't get either optical drive to boot up the windows CD on the new PC] and tried it again. Same error. I'm not reformatting the entire 250GB drive because I need the information on the big partition.
Another thing I tried was removing the prior installation of XP Home from the boot.ini to see if that was the issue. Didn't work either.
So I'm clueless as to what to do. I do not want to use the IDE Drive as anything permanent in this new computer. It's loud and useless. If I have to reformat it to do what's needed, temporarily in the NEW PC, fine. But I'd like to just run a new XP off the 3rd partition on the single 250GB drive and add in more drives as I need them.
So, any ideas on how to fix this? :| Is there maybe a way to switch masters so that the IDE drive relies on the SATA to boot into it's OS? Because at this point I'd be cool with just drop kicking the 40GB into a trash can and buying a new one if I decide to do something with it. The drive letter on the IDE for the OS is C:\ and the new partition installation I just finished on the 250GB is F:\
NTLDR errors are the only windows error that fucking get me everytime. I've spent 3+ hours now trying different crap and I've come to the conclusion that a] Doing what I'm trying to do is a BITCH from hell and b] Never buy a new rig without some sort of blank drive laying around.
And if it matters my new Motherboard is a Gigabyte P35-DS3L
thanks.
thanks.
