New rig, gonna WC, need help !
swflbatth
Ok, here is the deal, I am trying to find a case to squeeze a full circuit (cpu, gpu and chipset) WC solution into. I do not want external components. I am opting for a dual-120 radiator to mount somewhere in the rig (most likely on the top, pulling in). I want a case that has (or can handle through modding) a 120 exhaust in the back. I am trying to avoid 80mm to keep the noise down. So I am going to need room up top for the radiator, and a wide enough case to fit a 120 on the back. Originally, I was going to go with the Lian-Li V1000. But, I am getting the OCZ-520 powerstream, which doesnt fit in the case. Also, it does not have a removable mb tray (which I want b/c I hate taking apart my WC to fix/swap things). So, (besides a UFO) what case can offer this?
