Ryom
- Oct 11, 2006
I decided to up my PC audio game a bit and got the following:
I got some cables from Monoprice as well:
I have Realtek HD Audio onboard sound. I used the TosLink optical cable to connect to the receivers AV1 input. I connected my satellites with speaker cables to the Front Speaker connections, and I connected the receiver's Sub1 Pre-out to the sub's Line-In with the RG-6 RCA pin cable, I set the Optical out to the default sound device on my PC. Then I set the receiver up for 2.1 sound, two small fronts and a subwoofer enabled and I powered on the sub. However, while I get audio output from the satellites the sub gives off no sound whatsoever.
Any ideas what could have gone wrong?
- YAMAHA RX-V867 7.2-Channel Digital Network Home Theater Receiver
- Polk Audio PSW Series PSW10 Powered Subwoofer
- Polk Audio RM8 Satellite speakers
- RG6/U 75ohm (for S/PDIF, Digital Coax, Subwoofer, and Composite Video)
- Optical Toslink Cable
- 14awg speaker wire and banana plugs
