OK, Im new to the sata drive, so I have a couple simple questions.
1st: I got this cableWD sata
Do I have to use that in conjunction with a molex connector, or will that cable suffice?
2nd. For my jumper settings. Im going to be using WD 80 GB as my "back up drive" the raptor will be my XP drive etc. Im going set the raptor to master, but if the WD 80 is second, and running off the ide, what will that be set to? Thanks.
3rd. I did some reading, all I do is slap in the drive, hook up the cables, configure it through BIOS (I have my mobo manual) and go from there correct?
I have an IC-7G.
Thanks guys.
I have an IC-7G.
Thanks guys.
