New PSU Questions
I'm looking to buy a black power supply with a 20pin ATX connector and stable rails. It's going to be in the 500W range with an outlet in the back for my hydor pump.
Kind of tired of painting power supplies now lol.
So I don't know where to find one and hope that someone can help.
I was thinking of getting the Vantec stealth power supply in black, but I'm not sure since it has the 24pin ATX plug. The 24 to 20 pin adapter would just add to cable length and I'm trying to go for a wireless look.
Thanks! :)
PC Power and Cooling has a 470 watt Silencer unit in black, (even the fan grill), it uses the 20pin atx connector, but no power outlet though.
LoL it looks like you can't have everything...if I go with the Silencer I'll need to install the PCI Relay for the pump which adds more cables. If I go with the Vantec I'll need to use the 24 to 20pin adapter...
Decisions...
I may go with the Vantec 520W...but if anyone can prove me wrong about not being able to have everything then prove me wrong. ;)
I've never thought of that. Do they sell it at Michaels? That's the only place I can probrably get to.
