I recently upgraded my computer to an athlon 64 3200+. While i was at it i upgraded my maindboard to an EPOX EP-9NPA+ultra to get pci-express so i also had to upgrade my video card to an EVGA 6800GS. I didn't yet upgrade the PSU. The old one is an Enermax EG365P-VE(FCA), a 350W psu with a 20 pin main socket and the 4 pin cpu power so I figured id try it. I hooked everything up and it worked except the video card wasnt getting enough power and geared down. I found out that the pci-e power adapter was missing so i decided i might as well get a little more juice and buy a new psu. After reading reviews and comparing similar builds I went with an enermax liberty 400W. Since my 350W seemed to work, I figured the 400W should cover any extra the vid card needed, especially since its made to handle SLI and dual processor boards.
I got the new PSU this morning and installed it. The main plug on this is a 20/24, meaning it can separate into a 20 pin and a 4 pin, or hook together for one 24 pin. I hooked it together for one four pin and plugged it into the 24 pin MB connector. Then I took one of the 4 pin 12V connectors and plugged it into the MB 4 pin connector. I plugged in my harddrive and the videocard. I turned on the system and everything turned off in the room. The circuit breaker had flipped for that room. I tried again this time without the vid card or HD plugged in, still flipped the breaker. So I tested with the old PSU and the system posted so I dont think anything else got fried.
My big question: Is this PSU dead (like a short thats drawing too much power), or have I connected something wrong here. Anyone else out there have a similar situation or setup?
Again thats an Enermax Liberty 400W, A64 3200+, and EVGA 6800GS 256MB.
