New project starting, have questions....
chrsharvick29
I'm building a new rig with a Cooler Master Cosmos S and I have several questions.
I have already taken the case apart so it can be painted and powder coated. I have my hardware except for WC and various other parts.
I'm going with a black and red theme built around an EVGA Classified. My ram and video card already match my theme so I'm not messing with that. The case is going to painted to match too. WCing tubes will be UV red and I need a way to activate the UV without much ambient UV light. Need some ideas for that.
How do I mount LEDs? I want to add them various spots and want to know if there are some brackets I can use. Probably 5mm red LEDs, need to find some of those too.
I want to change all the connectors to black, mainly only need fan and 4pin molex. I'll also sleeve everything with black mesh. Need to find a good quality kit for that. I might do some custom wiring too so might need pins and tools to do that. I think I saw some stuff at performance-pcs.com that will work, but I need to be pointed the good stuff. Thanks for the help!
