Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
So I just got a purdy new Dremel 300 kit off of ebay for cheap.... should I practice before using it? In all my years of wood working, etc, I've never touched one of these before to be honest.
Pretty simple to use, I think the material is gonna be what you should worry about more than the tool. If you've never cut alu I would practice first, it's much different than wood (duh). It sucks to have to file/polish out mistakes that could've been avoided, or even worse ruin a case because you didn't know what you were doing.
I'll just be cutting some hole in the mobo tray portion on my antec 900 to get some cables out of the way. Anyone here have any experience with this case?
