New Phenom Build - Please advise
Lrdtalon
*** I have revised the build list below. Please check it out, is it worth it to go for the 955 or should i go for the 940?
Ok so like many people i got married and have been out of the game for a while. i tried to go the laptop replacement route, but in order to make the laptop work i had to get so many periphereals that i might as well have a desktop, plus it kind of defeats the purpose that i got the laptop for which was to be able to hang out with my wife and surf the web while she uses her laptop.
Long story short i am looking to switch back to a desktop to free up my laptop and be portable with it again and be able to do the things i want to do on my desktop. Here are the answers to the questions:
- Mild gaming, photoshop, browsing, video ripping/converting. itunes
- like to stay less then about 700$ with shipping and tax
3) Where do you live?
- Washington state
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
- Motherboard
- Processor
- RAM
- Video Card
- Case
- Maybe powersupply (i have a true power 430)
- Harddrive
- CPU Cooler
- I have a Antec True Power 430 might be 420 can't remember, i would like to reuse it, but not a requirement
6) Will you be overclocking?
- Maybe, but not incredibly hardcore
- Have a Samsung 245BW
- Once the wife oks the purchase (hopefully in the next month or 2 :))
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
- Nothing specific per-se
10) Do you already have a legit and reusable/transferable OS key/license?
- Yes (Vista Ultimate) would prefer to run 64 bit
Here is the prospective build so far:
Case - COOLER MASTER Mystique RC-632S-KKN1-GP Black Aluminum/ SECC ATX Mid Tower Computer Case - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16811119129
Motherboard - GIGABYTE GA-MA790XT-UD4P AM3 DDR3 AMD 790X ATX AMD Motherboard - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128378
Powersupply - Antec Basiq BP500U 500W Continuous Power ATX12V Version 2.01 Active PFC Power Supply - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371004
Heatsink/Fan - COOLER MASTER Hyper N 520 RR-920-N520-GP 92mm Sleeve CPU Cooler - Retail
http://www.newegg.com/Product/Product.aspx?Item=N82E16835103057
CPU - AMD Phenom II X4 955 Black Edition Deneb 3.2GHz Socket AM3 125W Quad-Core Processor Model HDZ955FBGIBOX - Retail
http://www.newegg.com/Product/ComboDealDetails.aspx?ItemList=Combo.192694
RAM - CORSAIR XMS3 DHX 4GB (2 x 2GB) 240-Pin DDR3 SDRAM DDR3 1600 (PC3 12800) Dual Channel Kit Desktop Memory Model
Well we really need your budget.
Before hand - I would get this Phenom over the one you picked. Why spend 50-70 dollars for a 200mhz overclock? I would save that and get a 260 GTX instead for 180.00 on newegg or a 4890 if you can find them in the mid-low 200.00 price range.
http://www.newegg.com/Product/Product.aspx?Item=N82E16819103471
Secondly, you can use the old Intel Quad platforms on LGA 775 if you're willing.
Put it like this
Intel LGA 775 Quad - Older Arc still strong and hanging on
Phenom II x3 or x4 - Really happy AMD is making a comeback and can compete once again for the budget/performance builder.
i7 920 = Overpriced for me, maybe not you.
i7 940 = Still over all overpriced to me.
I recommend if you want to save as much as possible and get as much performance as possible Intel Quad on LGA 775 socket or Phenom II x3 or x4
x4 is better if you have the money and just don't want to risk unlocking the 4th core.
P.S. If you're willing to spend that much for the processor, then I think you could afford to jump to the i7 bandwagon, IMO.
The budget question was answered in question #2, but i am looking at about 700$.
