New PC2700 + FSB troubles
styckx
Just upgraded my PC2100 to some new PC2700
Heres the specs
2 512mb PC2700 in single channel formation
AMD 2400 TB
MSI k7n2 nforce2 mobo/chipset
Currently my FSB is set to 133, soon as I set it to 166, I can't boot, monitors get no single, machine just runs w/ no activity..
SiSoftware Sandra
Mainboard
Manufacturer : MICRO-STAR INTERNATIONAL CO., LTD
MP Support : No
Model : MS-6570
System Memory Controller
Error Correction Capability : None
Number of Memory Slots : 3
Maximum Installable Memory : 1GB
Bank0/1 - A0 : Empty
Bank2/3 - A1 : None None None None DIMM 512MB
Bank4/5 - A2 : None None None None DIMM 512MB
Chipset 1
Model : Nvidia Corp nForce2 AGP Controller
Bus(es) : ISA AGP PCI USB i2c/SMBus
Front Side Bus Speed : 2x 134MHz (268MHz data rate)
Maximum FSB Speed / Max Memory Speed : 2x 200MHz / 2x 200MHz
Width : 64-bit
IO Queue Depth : 8 request(s)
Chipset 1 Hub Interface
Type : HyperTransport
Version : 1.00
In/Out Width : 8-bit / 8-bit
Speed : 2x 200MHz (400MHz data rate)
Logical/Chipset 1 Memory Banks
Bank 0 : 512MB DDR-SDRAM 2.5-2-2-0CL 2CMD
Bank 1 : 512MB DDR-SDRAM 2.5-2-2-0CL 2CMD
Channels : 2
Multiplier : 4/4x
Width : 64-bit
Power Save Mode : No
Fixed Hole Present : No
Memory Module(s)
Memory Module 2 : SpecTek 180457F9 512MB 8x(64Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 up to 167MHz) (CL2 up to 100MHz)
Memory Module 3 : SpecTek 18045868 512MB 8x(64Mx8) DDR-SDRAM PC2700U-2533-700 (CL2.5 up to 167MHz) (CL2 up to 100MHz)
Environment Monitor 1
Model : Winbond W83627HF ISA
Version : 2.01
Mainboard Specific Support : No
Temperature Sensor(s)
Board Temperature : 41.0°C / 105.8°F
CPU Temperature : 53.0°C / 127.4°F
Power / Aux Temperature : 13.5°C / 56.3°F
Cooling Device(s)
Auto Fan Speed Control : No
CPU Fan Speed : 1350rpm
as far as voltages go, it's all set to H/W
Whats your cpu.
If it the 2400+ in your sig line then they are supposed to run 15x133 for 2 Ghz.
At 15x166 for 2.5 Ghz is pushing the chip to the very max.
You may have to drop the multi down to 12.5 to get it to post.
Luck........:D
I have an MSI Board (MS-6712) with a 2600+. I had similar problems. What I determined is this: Leave the Multiplier and everything else in Auto. Change the FSB setting until it becomes unstable on boot up, then back it down. Every time I changed the multiplier I couldn't boot and had to reset the Bios.
