new pc
how do you think this pc will run?
Windows Vista™ Home Premium (32-bit)
Intel® Core™2 Duo E6600 (2.40GHz 1066MHz FSB 4MB cache, non-HT
2GB memory
NVIDIA® GeForce 7600GS 256MB PCI-E
500GB 7200rpm Serial ATA hard drive w/ Raid 0 (2-250GB hard drives)
16x Double-Layer Multi-Format DVD Writer (DVD±/R±RW/CD-R/RW) and 48x/32x/48x CD-RW/DVD combo drive
Sound Blaster X-Fi XtremeMusic 7.1
9-in-1 media card reader
700WATT PS
Sounds great congratulations.The only but I have is your video card if your a "gamer".Sounds great though good luck with it.
Looks great! I have a couple of queries, though. What power supply is that you have listed? Also, if you want to save a bit of cash you could probably do without the sound card and use the motherboard's onboard sound; which brings me onto my next question, what motherboard are you going to have in there?
I'd reccomend the Corsair 620HX. High quality, modular, and sexy too. I'm working on a simular build but with a 8800GTS. Plenty of power.
don'tcha think taht 700 watts is a bit much for that computer. a 400 would suffice.
depends on what manufacturer. if its a good one a 400 might be enough
And if its Apevia, you'll need a "700W" just to get 400W, ehhe.
Anyhow, that looks like a prebuilt or custom config to me. Where from? Bump up to the 7600GT if you play any games. If not, bump down to the 7300LE, hehe.
im getting it from gateway. i know a gateway. but right now that is the only way at this time to get me a new pc. on my girlfriends moms account. lol.
but it comes with the 700 watt because it can work dual video cards. the pc is called FX530 . just getting the tower.
Personally, I'd check the cheapest video card option and buy your own card and pop it in.
