New Pc Wont Boot Help Plz
angryzoo
I ordered a new pc last week and when i built it together everything plugged in and seemed ok but when u plug the atx12v power (the one with 4 holes) my computer turns on for 2-3 seconds then shuts off but when i unplugg the atx12v power my computer runs but no bios or lights show up on the mobo or screen.
specs
AMD Athlon 64 X2 3600+ Brisbane 1.9GHz Socket AM2 Processor Model
A-DATA 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit
MSI P6N SLI Platinum LGA 775 NVIDIA nForce 650i SLI ATX Intel Motherboard -
APEVIA X-Pider ATXA2XP-AL/500 Silver Aluminum ATX Mid Tower Computer Case 500W Power Supply
Sounds like a crispy critter mobo....just had one do the same thing after I got all the XP updates donlodes and all the sortware configured......:mad: pissed me of
:p
although you could try posting it with video card, memory, and processor only on the bench...out of the case...I have seen an optical drive cause funky problesm as well..........
I made a mistake on the specs cause I copyed the wrong saved wished list from the newegg thing. Here it is the motherboard I have
MB BIOSTAR TFORCE 550 GF550 AM2
Connect a case speaker, and remove all the RAM
Listen for any beeps. If there are no beeps, then you're motherboard needs to be RMA'd.
Sucks, but such is life :eek:
