Uncle Meat
- Apr 29, 2008
I purchased a Dell XPS 720 H2C from the Dell outlet. First thing I did after it arrived was wipe the HD's and loaded a fresh copy of Vista Home Premium 64-bit SP1. I then loaded the latest drivers for the hardware, and then a registerred copy of 3DMark06. I ran all the 3DMark06 benchmarks using the default settings except for resolution which I set at 1920X1200 because that's native for my monitor. My 3DMark06 score was 14430. Does this sound about right based on my hardware/software?
Here are the specs:
QX6850@3.00Ghz
6GB Corsair Dominator DDR2@1066Mhz
2X250 GB SATA Hard Drive (Raid 0)
Dual 768MB Nvidia GeForce 8800 Ultra SLI
16X DVD +/- RW
48X CD RW/DVD
Sound Blaster X-Fi XtremeGamer
2407WFP-HC 24"
I loaded up Crysis and patched it to v1.2. Set all settings to "High", no AA, and no extra config tweaks. The gameplay (FPS) however drops down to an almost unplayable level at times. I figured with this rig that Crysis should play a little smoother than it does...
Any input would be greatly appreciated.
U.M.
Here are the specs:
QX6850@3.00Ghz
16X DVD +/- RW
48X CD RW/DVD
2407WFP-HC 24"
U.M.
