New PC Build
Hardlife
Hi people,
Not sure if im in the right section... navigating this site with my droid. If im not in the right area please move thread.
Well i took the challenge and built my first PC and happy that i did. Just like putting a puzzle together... it was fun.
Now here are my issues after turning it on to install windows 7:
The top front I/O panel started smoking... coming from the PCB board i believe they call it where all the fan and LED wires are soldered onto the CM Sniper case. I shut it down and repositioned the wires and turned it back on... same issue. Rinsed and repeat... not smoking anymore.
Put the windows 7 CD into the drive to try to install... blank screen. Also, the RAM red light is on by the DIMM slots. I would appreciate any help to resolve my issues. Thank you.
Take a look at the troubleshooting sticky for suggestions.
We also need the full specifications of your system.
