New PC Build...thoughts
Ingonuts13
Intel e6600
ASUS P5B Premium Vista Edition
4x1GB Buffalo Firestix or should I do 2x2GB instead?
8800GTX EVGA KO
VISTA Ultimate 64
This will go into my existing W.C set up for some mean overclocking. Any issues or concerns? I am still torn on the Ram or Motherboard really.
looks good. whether or not you need 4gb of ram depends on what you do with the system.
IMO the 4x1GB sticks would be a better choice in terms of memory. Also AFAIK, the KO Edition of the 8800 GTX does not have that much of a cooling difference when compared to normal 8800 GTX's and most normal 8800 GTX's can overclock to the speeds of the KO Edition, so I would go with the normal version of the 8800 GTX.
Why do you say 4x1GB is better? Also, the reason I went for the KO edition is kind of a guaranteed overclock since I will be watercooling the card anyways. I will take a look into the regular version as well, though I am not sure what the average overclock is on those.
I would go for the 4x1 GB because it is cheaper to find 1GB sticks and you have more choices. Also, if you really want that guaranteed overclock, then getting the Superclocked version would be a cheaper alternative than the KO Edition for almost the same clock speeds (5 Mhz less for the core clock).
With each stick of RAM, you increase the power requirements too. I still don't see an advantage to buy 4x1GB instead of 2x2GB sticks. Yes it will be more expensive, but if you need to troubleshoot something, it becomes a whole lot easier with less parts.
