New PC build problem/issue.
HalfBaked
Hi, So I just built my new rig a few days ago, everything went smooth except this. If I bang down on my desk with my fist preety lightly my monitor will loose signal and sometimes it restarts. Now I traced this to my PC express 1.0 sound card not fitting correctly and that eliminated it. Tho hour later just to kinda test my previous solution, I TAPPED my case with my finger and it looses signal. I took ram,video card etc, everything out and put it back it making sure nothing was loose. I am kinda leaning towards the problem being my Zalman heatsinc sliding around, It does slide VERY slightly but i dont know. Any ideas
case Lian Li PC-60BPLUSI
mobo : ASUS AM2 M2N-SLI Deluxe nForce 570
video card is a BFGtech 8800GTX 768Mb
ram is 2x1gb ocz
sound is a soundblaster 7.1 xfi
The pc stays on, the monitor is what looses signal. I always thought shorting would kill the whole rig.
