New PC Build not posting... any suggestions?
Krycek1
I just put together a new PC and it turns on and beeps once but the monitor just stays black. Both my mouse and keyboard lightup and everything seems to be working.
Any suggestions? I've tried using only one stick of ram and using different harddrives but nothing seems to work.
Here are my specs:
E8500
ATi 4850
Asus P5Q SE Plus
G.Skill 4gb (2x2gb) 1066
PC Power & Cooling 610 watts
IDE master cabled Wester Digital Harddrive with Windows XP installed.
I'm going to post a picture in a few minutes to see if anyone can notice an error.
Have you tried a diff monitor or video card yet?
Unfortunatnley, I don't have another video card (with PCI express) but I know it's not my monitor since it worked perfectly with my old monitor using the same DVI connection.
okay remove everything that is not essential to the PC needing to be on...
have only the following connected...
ATX power Swtich
PSU
CPU
CPU HSF
1 stick of RAM in the correct slot according to the manual
disconnect all USB devices, HDD LED, extra RAM, HDD, FANS and such
then see if it posts... if it does connect everything else one-by-one until it doesnt post...
ATX power Swtich
PSU
CPU
CPU HSF
Thanks for the suggestion because I know where you're coming from but after disconnecting all those things it still didn't post.
Does it matter which of the two DVI slots i pug my monitor into? When I do have everything plugged in (mouse, keyboard, etc) the beeping indicates that it detects my ram and graphics card (the fan also spins on the graphics card) but for nothing posts as well. Is it possible that even though it detects my video card and such that it's broken?
try the other DVI slot,
also try clearing the CMOS on the motherboard and make sure it does not have a switch or connector in the clear position
also you connected that 4 pin CPU power connector way up in the corner right?
I actually went to best buy and got a new video card to see if that was it and I tried both DVI slots and neither worked.
I tried clearling cmos and nothing.
And I've got the 4 pin CPU power connector connected.
This is truly bizarre. I'm going to get my camera to take a picture and maybe someone can spot the error. I'm ready to pay out cash (via Paypal or something) if someone can come up with the idea that works.
so you got a new video card to test and that did not work either?
i would try to reseat the CPU, take off the HSF pull the CPU out and put it all back together
ok, i will try this next. But if the CPU is seated wrong, would it still be making all the normal bootup sounds. Everything accept the monitor seeminly turns on and beeps once like you would expect (the fans spin on everything the motherboard light is green, etc.)?
I'm looking on google and there are known RAM problems with this board,
try one stick of ram in different slots and see if you can get it to post
The manual says it accepts this exact model of ram and I've tried just using one of the sticks in basically every slot with no luck :(
Here are two pictures of what i'm working with.
As you can see I even tried disconnecting the IDE cable to the hardrive which is the master.
What monitor do you have and what cable are you using to hook it up to the video card?
Ok, thanks a ton for everyone's suggestions. I finally figured out what the problem was. Apparently, my monitor wasn't compatible with my video card. Even though it is DVI and work with my old ATI AGP video card it doesn't work with my new ATI PCIe video card which is really strange. It took me plugging it into my tv to figure that out. Very weird problem to have which is why I was about ready to give up but thanks for the suggestions again.
Well I hope that helping you out gave you faith that you CAN actually build those technological marvels we call computers ;)
Have fun with the new PC!
You might try a new DVI cable before pronouncing your monitor incompatible. There really should be /no/ situation in which that's the case.
