New PC build help
BBruins
Web browsing, Office work and gaming. My computer is six years old.
800.00 U.S.
MN USA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word
Everything case, motherboard, video card(dual monitors or maybe three) , hard drive, memory, power supply.. everything in the case....
"Everything" is not a valid answer. Please list out all the parts you'll need.
None,
6) Will you be overclocking?
Probably not.
24' monitor dualies or maybe three
now.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
Anything you guys recommend.. USB 3.0 sounds good.
No.
Thanks for your help.
