Building a new PC for a friend that is starting a veterinary practice. The computer will be used as peer workstation/server for 2-3 users using Surface Pro 3 tablets and needs to support system requirements to run vet software made by Avimark.
http://www.avimark.net/avimark-software/hardware/
Looking to build something that's a little more future proof than their recommended specifications. Given what it's being used for, just need a generic graphics card.
This is my 3rd build but over a 7-year period, so looking for any suggestions on cost savings or other improvements while keeping about the same price point.
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc - Workstation for small business
2) What's your budget? Are tax and shipping included? - ~$1,000 with shipping
3) Which country do you live in? If the U.S, please tell us the state and city if possible. -USA - PA
4) What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need. - Complete build - CPU, motherboard, ram, graphics card, hard drives, power supply, dvd burner, case and OS
5) If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. List make and model. - None
6) Will you be overclocking? - No
7) What is the max resolution of your monitor? What size is it? - Will purchase a monitor separately, probably just 24" 1920 x 1080
8) When do you plan on building/buying the PC? - Hopefully building next weekend
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc. - No high end specifications on motherboard, support 2-3 hard drives, 4 ram slots
10) Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? - Will purchase new Win7 Pro 64bit license.
Initial build (w/ Newegg pricing):
Intel Core i7-4790K 4.0 GHz LGA 1150 - 339.99
GIGABYTE GA-B85-HD3-A(rev. 1.0) LGA 1150 - 79.99
G.SKILL Ripjaws X Series 16GB (4 x 4GB) DDR3 1600 - 94.99
SAPPHIRE Radeon HD 5450 - 1GB 64-Bit - 39.99
CORSAIR CX series CX430M 430W Modular Power Supply - 49.99
SAMSUNG 850 EVO MZ-75E250B/AM 2.5" 250GB SATA III 3-D Vertical SSD (w/ mounting bracket)- 104.98
Western Digital Blue WD10EZEX 1TB - 52.99
Windows 7 Pro SP1 64-bit - 139.99
ASUS DRW-24B1ST - DVD Burner - 19.99
Corsair Carbide Series 200R Black Steel / ATX Mid Tower Case - 69.99
Total: 992.89
Total: 992.89
