New PC Build Advice
greatchap
The NH-U12S will set me back by $63. Thus my cost increases to $280 if I shift from i5-8600/K to I-9600K. I don't know if its worth the extra $280.
TheFlayedMan
An alternative would be a Cooler Master Hyper 212 EVO. I think you should buy a i5-8400 or i5-8600 with the H310 board and an aftermarket cpu cooler. This is because the one that comes for free is loud and you don't want that.
greatchap
I am gonna stick with i5-8600 series.
1) In case I get i5-8600K at the same price as i5-8600 should I buy i5-8600K.
2) If I go for i5-8600K I will buy cooler Cooler Master Hyper 212 EVO. Is that fine ? Even though I know I cannot overclock it using the H310 MB.
Now I was looking around and found out that for an extra $60 I can buy Samsung 970 EVO 500GB M.2 rather than Samsung 860 EVO 500 GB I was buying earlier. The speed difference is huge.
Thus I wanted to know if I should go for it ? However the H310M-H board does not have a slot for that. So what to do ?
TheFlayedMan
1) yes
2) yes buy the EVO 212
3) the speed difference between those drives is huge in benchmarks. In real world usage the speed difference is more like 10%. I would buy the 860 Evo. Second thought I would buy a 500GB Crucial MX 500 as it's almost as fast as the 860 Evo but cheaper.
greatchap
1) yes
Great !!!
I will go for i5-8600K. I will also go for 500GB Crucial MX 500 instead of Evo.
On the MB front since I am not going for M2 ssd and neither I am overclocking I will go for H310 MB. However in case I decide to go for a better board can you recommend me one hat is better than H310 but not as expensive as Z390 series. (Something in the middle)
TheFlayedMan
Great !!!
I have a fondness for MSI so I'm going to say the MSI B360 Gaming Plus. The Asrock B360M Pro4 is also well regarded. The Gigabyte B360 Aorus Gaming 3 is another option. The Asus ROG Strix B360-F Gaming would also do the job.
Any of those boards would work for your build.
greatchap
Thank you. Except for Asrock B360M Pro 4 the other boards cost almost as much as a Z370 / Z390 board here.
