New "not" high end build help please.
harsaphes
1. What will you be doing with this PC? Gaming, Photoshop (or other intensive programs), Web browsing, strictly HTPC/Playback, etc. (If you have multiple things you want to do with the system, make sure you rank them from most important to least important).Very light gaming. Playback from Amazon/Netflix ect. Web browsing.
2. Will you be overclocking? (If so, are you looking to watercool?)
No overclocking
3. What's your budget? Are tax and shipping included in this budget? Is your budget flexible? Is cost a driving factor in component selection?
I would love to stay under 1000
4. Where do you live? Do you have any big B&M (brick and mortar) computer chains nearby (e.g. Microcenter, Fry's, etc)?
NYC. I actually dont know. BandH photo?
5. What exact parts do you need for that budget? CPU, RAM, case, etc. The word "Everything" is not a valid answer. Please list out all the parts you'll need (especially if you will need 3.5" hard drives or expansion cards as these may restrict case options).
I'm reusing an old Maingear Xcube box so I dont need a case. I need Micro ATX board, cpu, ram, video card. I have a sound card and I think I can reuse my power supply. Video card must have HDMI out.
6. If reusing any parts, what parts will you be reusing? Please be especially specific about the power supply. For reused parts, list brands, model #s, and, if applicable, firmware revisions.
Reusing the Maingear Xcube box, also my SSD, sound card and dvd drive. I don't know what the power supply is at the moment because Its in a cabinet and I dont want to look right now
7. What specific features do you need in a motherboard? RAID? Thunderbolt? Crossfire or SLI support? How many USB 3.0 and SATA 6Gb/s? etc. Which is more important, size of the system or having the particular feature? Make sure you indicate *required* vs. *wanted* for each feature you list.
I really just need something standard. USB 3.0 would be nice
8. What resolution output do you need? 4k playback, 1080p playback, etc for HTPC or give a vertical/horizontal resolution for gaming SFF rigs. Do you need multiple monitor output?
1080P. Will be connected to a Pioneer Plasma
9. Does this system need to fit into a particular space and do you need an optical drive? Think entertainment center shelves, closet space, rackmount, etc. Many modern SFF cases have either removed the optical drive or have been constructed so that removing the ODD increases the configuration possibilities immensely.
Using same case that is in the space now
10. How comfortable are you with custom case design/modification and electrical wiring? What tools do you have (Screwdrivers/Leatherman, Drill, Dremel, Metal snips, Soldering Iron, Bending Brake, CNC/Welding machines/Plasma cutter, etc...)?
Dont need
11. How important is the noise/silence of this sytem? HTPCs typically want to be quiet while all-out SFF gaming rigs don't care
Quiet or sort of
12. How mobile does this system need to be? Need a carrying handle or carrying straps? Is weight important (carry-on bag, etc)? Water cooling quick disconnects, etc?
Dont need
13. Do you already have a legit and reusable/transferable OS key/license? If yes, what OS? Is it 32bit or 64bit? Remember that OEM copies of Win7 have issues with new motherboards
Have a key. Win 10
14. When do you plan on building/buying the PC? Immediately, in a couple weeks, 3-5 years?
Next couple weeks
Thanks for looking.
__________________
Here you go:
http://pcpartpicker.com/p/f3cw4D
You should buy a new power supply if your existing one is older than 3-4 years because it could be incompatible with the Haswell sleep states and/or may not be able to deliver enough performance.
I've dropped in a GTX 960 for you, but if you only need light gaming, a 950 should also work. If you were not gaming at all, even the CPU iGPU would work.
If you want absolute silence, be sure to check out CPU coolers. For relative quietness in idle/browsing/movies the stock Intel cooler should work.
Have a nice day :)
Just an FYI, here's the 4 NY MicroCenter stores:
NY - Long Island/Westbury
NY - Brooklyn/Gowanus Expy
NY - Queens/Flushing
NY - Westchester County/Yonkers
Honestly, that vidcard is overkill. If all you're doing is basic web browsing and movie watching, you could get away with using the integrated GPU and save yourself the $170.
For storage, well, considering the fact that the CPU, board, memory and PSU will cost you about $300-350, do yourself a favor and just get a decent SSD in the 250-256GB range (big enough for the OS install, a few apps, plus whatever Windows Updates come along).
A Samsung 850 Evo 250GB will run you about $90.
The slightly better (and longer warrantied 256GB 850 Pro would run about $132.
If you need ACTUAL storage, a 4TB HGST will run you about $170.
So, for around $700, you have a non-high-end build and money left over.
Thanks. I'm actually going to reuse my current SSD, DVD drive and sound card.
So I went ahead and bought an i7 NUC. 16gigs ram, 500 m.2 drive. Amazing how small it is and how silent. I'm loving it.
