New Motherboard
rubic
I need to put a new system together for a database project that I will be doing soon. I need about 400gb of disk space and I'm planning on using two SATA hard drives at 200gb each in a raid 0 array. It's possible that in the future I will need to add more hard drives to the system so I am looking for a motherboard with 4 SATA connections instead of the usual two (not sure how the raid controller will handle adding drives but I'm pretty sure it can be done). My plan is to use an AMD64 3000 but that really is not set in stone so a P4 would probably do just as well.
Probably the most important factor is going to be that the motherboard must be stable and well supported. I don't plan to overclock or use this for gaming so there is no need to worry about those issues.
What do you guys suggest?
Well, if the database is important I would not use RAID 0 since you'll loose the whole thing if you loose one drive. RAID 5 would be a better option since you get speed and fault tolerance. The down side is it will be more expensive to setup.
As for a motherboard, when it comes to something for business, I tend to go with Intel server boards and Adaptec controller cards. That being said, the MSI Neo 4 Platinum as it supports RAID 5 and 10 via the Silicone Image controller if the A64 3000+ you mention is the 939 version.
I've been looking at the MSI Neo 4 but I was not sure if any known problems existed with that board.
Money is a factor on this build and that is why I am leaning towards the AMD instead of Intel. I agree that RAID 5 would be best but this database will remain static (won't be updated) once installed and a simple backup should be adequate in case of hard drive failure.
Thanks for your help :)
