New Motherboard?
Atragon
I've already posted this in Overclocking and Cooling but receivied no response, so I'm reposting here in the hopes that this is a better venue for this kind of post.
I've got an XP2100+ (the old palomino core) running in a GA-7VRXP Rev1.1 with a ThermalTake SilentBoost cooler on it, and I'm considering overclocking to carry me through till the Paris based AMD chips come out. Now, I've been able to crank the bus speed up from 133 to 145 with perfect stability in Sandra's Burn-in wizard overnight. However, it freezes before even completing a single loop of 3DMark2001. When I dropped the FSB down to 142, 3DMark runs without a hitch.
This seems to indicate that my video card really doesn't like a boosted AGP bus. So my question is this, do you think I would see good gains with a modern motherboard?
(Important note, my RAM is PC2700, rated for CL2.5 at those speeds)
I wouldn't spring for a motherboard because your CPU will still be what it is and won't overclock too much more with a new motherboard anyway. What kind of video card do you have?
Overclocking does help to improve performance but it will usually not make the difference between a playable frame rate and unplayable. If there is a game that you can't play right now I really don't think overclocking your 2100+ is going to change that. Call me stupid but I don't know which "Paris" AMD's you are waiting for. Is that going to be a later generation of the 64-bit line or something? Is there a game that you can't play right now because of your system specs?
Paris is the codename for the next generation of AMD 64-bit CPUs based on a 90nm core. As for OCing, framerates are around 1-5 FPS low in some games.
XP2100+@1846, 13X142 (Palomino Core, Thermaltake silent boost)
1024MB Samsung PC2700 RAM @177, 2.5-3-3-3-7 (2 DIMMs)
Gigabyte GA-7VRXP Rev1.1
MSI GF4 Ti4600 (stock speeds and cooler)
Aureal SQ2500
3Com 10/100 NIC
Maxtor DiamondMax9 80GB 7200RPM
DVD-ROM
40x12x48 Lite-On CD-RW
Enermax Whisper EG365P-VE power supply.
When I bump the FSB up to 145, I can run sandra's burn-in wizard all night with complete stability, but 3dMark hard-freezes when it makes it to the lobby test. With the FSB down at 142, both sandra and 3dMark are rock stable all night.
(Which is why I'm thinking of a new mobo to lock the AGP and PCI bus speeds.)
Doesn't that KT333 board have a AGP/PCI divider for 166mhz? I could have sworn my Abit board did.
Technically it does, however it isn't easy to set, and I'm not sure about boosting my CPU up to 166 straight up.
That GeForce 4 should be pretty good, unless you're playing above 1280x1026 in 32-bit in most cases.
You might try a newer driver for the card if nothing else, along with updating your chipset drivers.
yes but on most boards it hates it
I'm using the Omega detonators, 44.03 in quality mode. HALO at 1024x768 in 32bit. Most games are fine though.
Don't worry about halo. It's a crapily ported game and you need killer specs just to run it decently.
Yeah, it's Halo, not the system. People with Radeon 9800's even have performance issues with that one.
