new motherboard for xmas, need help figuring out RAM
isnwbored
ok so heres the deal, i just got a new motherboard and proccessor for xmas, its a nforce 570 from abit http://www.newegg.com/product/product.asp?item=N82E16813127008 it states that it supports ddr2 memory, and its got 4 slots for ddr ram, two are green and two are orange, only thing is, i dont have any ddr2 memory! i do have 4 sticks of regular ddr ram, can i use them in this motherboard? and if so, can i only use 2, or can i use all four? any help would be extremely appreciated!! i cant even put it together yet anyway until my pcixpress vid card comes and the heatsink/fan, but if it does only use ddr2 im not gonna be able to boot this thing up for another 2 months until i can afford some new ram!! :confused: :(
thanks in advance!
DDR and DDR 2 memory have a different pin configuration. They are not compatible. If a motherboard has four slots, you can always use all four.
The misconception there is from the old Socket 754 and earlier Socket 939 days. You always could use all of your slots, but you would have performance issues when four memory modules were installed. Some machines had to reduce the clock speed of the ram to 333MHz from 400MHz, and up through the Socket 939 days, you'd have to use a 2T command rate, as 1T wouldn't be stable, or just flat out wouldn't work at all. With Intel systems, the misconception occured because of the i875P chipset being unable to use PAT when all four slots were populated. The performance loss was about 3%, but in my experience having more physical memory was worth that reduction in performance.
Additionally, 4 modules sometimes results in having to increase timings in order to make the system stable, but this is rare. When overclocking, having four modules is undersireable because it can hurt your machine's overclocking potential. When overclocking you want no more than two modules as the odds of four modules being capable of the same exact overclocks are highly unlikely. When memory is purchased in matched pairs, (dual channel kits), two modules are tested to perform to the same specifications and therefore the two modules should have similar overclocking potential.
Hope this helps.
Sorry, but 168 pin DDR RAM will not work in place of 240 pin DDR2 RAM. It might fit but you won't like the result.
It won't fit unless you force it, and in such a case, it will only fit because something broke.
